Mk 2 3.4 litre automatic speedo
Hi all I have a 140 mph speedo in my mk 2 jag autothe Tpm is 1100 the speedo is erratic and reads low most of the time does anyone know the correct type of unit for this year of car and also the tpm for a std car (USA export originally lhd) the car I think has a std axle and bw gearbox 1961 car should this car have a 140 speedo in it?????? Any light shone appreciated
Re: Mk 2 3.4 litre automatic speedo
Just in case anyone is interested but too shy to ask the 1100 tpm speedo seems correct for this model problems were an oiled up cable contaminating the sppedo head and a pointer not set at the white dot just below the 0 mph stop. Works fine now to within 2-3 mph
I think most models of this era got the 140mph speedo as the e-type had it. Commonality accross the model range saved money & probably did no harm to sales if your Mk2 speedo went higher than the car could...
ecosselynx
Just for information, while 2.4 cars had 120 MPH speedo's and 3.4 & 3.8 cars had the 140 speedo'd the important thing is the TPM (Turns Per Mile) which is the caliberation figure. The speedometer installed into the car was dependent on the gearbox and rear axel ratio to ensure correct indicated road speed.
bye-o
John H.
John H.
Just to finish the post the tpm 1100 is correct I have got the speedo working now problem was oil contamination and pointer having been pushed on c 5 degrees too clockwise, still a bit wavery and out a bit above 70 prob needs a professional rebuild but good enough to keep me out of trouble with the cops
Richard
Richard
