Mark 2 Heater
Posted: Tue Jul 19, 2016 10:13 pm
Hi.
I have a Mark 2 Jaguar 3.8 1965 that seems to have a part missing.
Think this should operate the top flap on the heater matrix box when you use the hot\cold lever in the car. This is out of stock at SNG Barratt. The water control valve on the matrix seems to have two levers one of which is connected to the cable from the car. I think the other lever on the valve should be connected to a rod which operates the top flap. The only way I can control the flow of hot and cold air into the car is by manually operating this flap under the bonnet. There are no fixing on either the valve or flap for securing the rod. Not sure if these has been removed at sometime. Have read somewhere this flap is sometimes fixed and this may be why rod and fixings have been removed. Other lever in car operates bottom flap for flow of air to screen\car.The lever that open flap in front of windscreen works okay.
If any one can help either by way of a picture or source for part it would be appreciated.
Thanks.
Thanks.
