Dash pannel
Lee83
Dash pannel
Postby Lee83 » Fri Mar 11, 2016 9:04 pm
What are the centre dash panels made from and why? Is it brass?
piman
Re: Dash pannel
Postby piman » Fri Mar 11, 2016 9:49 pm
Hello Lee,
off hand I can't say but I would be surprised if it is brass, too expensive, William Lions was quite economical with his production. I would expect it to be mild steel sheet?
Lee83
Re: Dash pannel
Postby Lee83 » Sat Mar 12, 2016 7:53 am
Hello Lee,
Copper plated maybe?
PPV
Re: Dash pannel
Postby PPV » Sat Mar 12, 2016 11:07 am
Hi, having just been working on mine doing a bit of wiring refurb etc I can say that they are all mild steel sheet, painted grey primer in my case. They are original so no brass I am afraid.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
Lee83
Re: Dash pannel
Postby Lee83 » Sat Mar 12, 2016 3:50 pm
Hi guys
Here is the one i have. Looks plated in copper but there is no green or rust on it.
oldtimer
Re: Dash pannel
Postby oldtimer » Sat Mar 12, 2016 8:15 pm
Very interesting comments, especially steel plate with grey primer, I wonder if the cost saving on the 240 and 340 went in that direction.
My memories of the time that it was copper not brass
Come on folks, help me , is copper magnetic ? To cold to go into the workshop and check.
If copper is not Magnetic then you have your answer.
If all fails try drilling a small hole that will soon tell you - copper is quite soft
Somebody will tell us
Oldtimer
oldtimer
Re: Dash pannel
Postby oldtimer » Sat Mar 12, 2016 10:13 pm
Hi Lee83 and others,
I have just ventured into the workshop and confirm that copper is not magnetic.
So, Lee try a magnet which should not stick.
Lee, Now you can confirm to us
Oldtimer
piman
Re: Dash pannel
Postby piman » Sun Mar 13, 2016 8:51 am
Hello all,
that is most peculiar, I don't believe that the dash panel is made of copper, same reason as before, too expensive and also copper is soft and so is more likely to distort than steel. That said it looks like copper so copper plated? The magnet will stick to copper plated steel.
Lee83
Re: Dash pannel
Postby Lee83 » Sun Mar 13, 2016 12:01 pm
I can confirm that after intensive magnet testing on the dash panel the magnet did stick! :P
So I'm guessing the it must be metal plate plated in copper.
I wonder why they did this???????
PPV
Re: Dash pannel
Postby PPV » Sun Mar 13, 2016 12:53 pm
Just tested mine. Defintely magnetic and therefore suggest mild steel.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
oldtimer
Re: Dash pannel
Postby oldtimer » Sun Mar 13, 2016 9:52 pm
I am amused at the attention this topic has attracted , at least we will never forget.
So we now all agree , copper flash over steel.
Will there be a rush on magnet sales just to check.
poprivet
Re: Dash pannel
Postby poprivet » Tue Mar 15, 2016 1:00 pm
If the instruments/light bulbs are earthed through the panel the plating would help with electrical conductivity I suppose.
