HELP
dave.johnson1322650
Hi--i have recently bought a 2.4 MK2---but one problem i have is the time clock in the rev counter isnt working--on checking there are no wires to it---i have found a live feed floating behind there,but presume i would need an earth wire as its mounted in wood---any help would be welcome----DAVE
Re: HELP
Hello Dave,
the rev counter should have an earth connected to it, simply run a small wire to that.
Howver I'd be surprised if the clock still work, they are well known for failing.
This company sells repair kits if you need to get it working. :- https://www.clocks4classics.com/repair-kits-918018.html
dave.johnson1322650
Re: HELP
ALEC----thanks for the info---DAVE
