Restricted Performance
Posted: Sun Jul 07, 2019 12:19 pm
Hello
My 2002 3.2L XJ8 was running perfectly yesterday but as I was parking the yellow MIL light came on together with 'Restricted Performance' and rough idling. I scanned it and these are the following DTC codes;
P0303 - Cylinder 3 Misfire
P1316 - Misfire
P0341 - Camshaft Position Sensor Circuit Range/Performance (Bank 1)
P0353 - Ignition Coil 'C' Primary/Secondary Circuit Malfunction
P1000 & P1111 - Which I believe are just test status codes
Does the rough idling throw out the camshaft sensor?
Then I got two further warning messages ASC and TRAC Unavailable. My day was quickly getting ruined.
I left the car a couple of hours and went out to move it to somewhere I could work on it and the MIL light and all messages had vanished and the car was running perfectly again.
Has anyone experienced anything similar and what was any solution please? Any info would be appreciated.
Thanking you in advance
P1316 - Misfire
