Bizarre request: photo of Premium sound system in boot?
Moderators:robv12, DavidEm
blackflash
Postby blackflash » Wed Mar 26, 2008 11:43 pm
Chaps,
I still have my fingers crossed that business will pick up and by the summer I will be able to afford the ICE upgrade which is subject of another (rather long, hence this) thread.
When I bought all the bits and pieces, I was asked (rather bizarrely, or so I thought at the time) if I had the carpet to go over the CD changer and amp to which I automatically replied yes. It's only now that I realise I have never seen the H-K amp installed in relation to the CD changer and that there is at least a small chance that the CD-changer-plus-amp lump may need a different carpet or hole-in-carpet.
I'm not too stressed about this as I'm sure a decent adaptation could be made if necessary but if someone out there with a Premium sound system would be so kind as to post (or email me if easier) a photo of the kit in situ then I'd be grateful. I'd like to make the car look as though it had the Premium system fitted "at birth", as you might expect.
Many thanks,
Nigel
Blackflash
'05 S-Type R in Liquid Silver with Dove leather and Aluminium trim
Postby Brakebuster » Thu Mar 27, 2008 5:09 pm
Nigel
if you have the existing cd changer in the boot ( X308 ) , then you shouldnt need the extra carpet or bracket, as i think it fits on top of the one holding the cd changer, and the same carpet will cover it
the only other modification to the carpet is when the sat-nav unit is fitted in the boot, it requires a higher bracket and therefor higher carpet section to go over it, with two slots for the devices
i will see if i can find a picture somewhere
