Car Aerial
Moderators:robv12, DavidEm
DougX
Car Aerial
Postby DougX » Mon May 08, 2023 10:04 am
My X308 car aerial failed to operate. The aerial doesn’t rise or fall. Took the cover off, and aerial inner connections are ok and still on the spline. Took connection off circuit board and put direct power to the motor and aerial went up without issue. It would appear the problem is with the circuit board. Does anyone know any firm that can check and fix the circuit board?
