In-car entertainment upgrade?
blackflash
Hi guys,
More praise for Eurojags subject to one glitch being ironed out...
Came back from a few days away to see two big parcels arrived from Eurojags. Having paid £100+VAT for a premium (H-K) sound system I was delighted to see that I had been sent the rear parcel shelf with built-in mesh for the sub-woofer and the two A pillars - in ivory to match my car perfectly.
I am chasing up the CD stacker which I requested as part of the package as mine has coincidentally started skipping only in the last few days - this wasn't in the parcels.
But I did get the sub-woofer, the amp, four door speakers, two tweeters built into the A pillars and two others.
Am I right in thinking that there are four tweeters altogether in both standard and premium systems but in the Standard system the front ones are in the doors (like in the back) and in the Premium they are in the A pillars only and there are none in the front doors?
Once I get hold of the CD stacker I'm going to see how much it will cost for a specialist to install this lot, fully expecting it will cost more to install than I paid for the kit! Though I'm pretty sure swapping the speakers over would be straightforward enough, I don't know the car well enough to start replacing parcel shelf and A pillars, let alone sorting out how to handle the wiring requirements without replacing the whole loom...
Festive greetings to one and all,
Nigel
Nigel
Blackflash
'05 S-Type R in Liquid Silver with Dove leather and Aluminium trim
cd player
Nigel re the stacker unit.....try emailing Rob Jenner he buys and sells stacker units.......hes at ....rob.jenner@tiscali.co.uk
im sure he will help even if he gives you another contact .....
blackflash
blackflash
installing the HK system isn't that hard to be honest
yes, it will need ' rewiring ' but not in the way you think,
the HK amp is mounted in the boot over ( or where ) the 6 CD changer is, you will need to run a new loom from this position to the stereo position in the front of the car, the existing loom stays installed as it is utilised by the HK system
the rear sub-woofer is part of this loom , the loom runs down the middle of the car under the carpet on the trans-tunnel after going under the back seat from out of the boot, then it runs under the arm rest console to the stereo, the loom links out some of the stereo wiring so the speaker side of things are amplified from the boot ,
the other things you have to do is replace each door speaker with a HK one, and remove the ' tweeters ' from each front door, and install the HK ones in the windscreen A-pillar trims , the wiring should be there already for this alteration,
the subwoofer is mounted in the rear shelf, and the revised shelf should be used, but you can modify the existing one
if you have rear blinds, you will have trouble fitting the sub
if you have the 6 CD changer, you need to link this to the amp with a special lead
system upgraded and installed
hope this helps
Ok, so I have the full kit and I have an outline quote from a well-respected Jag specialist and we're looking at a few hundred quid. I just want to do a sanity check as we seem to be talking about a full replacement of the wiring loom here...
I understand that he/we will need to:
Remove centre console to plug new loom into back of panel
Remove and replace all door panels to put new woofers into doors
Replace A columns
Replace parcel shelf (I have the sub-woofer-specific one) which means removing the rear seats
Remove and replace rear door tweeters
Insert HK amp over existing 6 CD stacker
Have I missed anything?
As you can imagine, this lot adds up to quite few hours work. It all makes sense except I'm not sure what you meant by the existing loom staying in place as my man is talking in terms of replacement not addition.
Still, even if it costs me a day's labour I can console myself it's a lot cheaper than the original owner would have forked out for the upgrade!
Can't afford it for a month or two but will let you know how it goes - and if it is worth it for the sound!
Nigel
hope this helps
Replace A columns
Nigel
Blackflash
Nigel,
your almost there, and well done on getting all the parts,
the existing loom stays in the car, and the HK loom plugs into the existing loom behind the stereo, this takes the wires back towards the amp, then there is another plug on the loom that goes into the back of the stereo , so think of the new loom as a link loom between the stereo head and speakers. speakers do not need rewiring, just the cones replacing
You will have to take the back seat base out ( possibly the back rest to ) but this has to be done to remove the parcel shelf, this is tricky to remove, as the rear upper side panels have to come out to, seat belts will need to be unbolted from under the seat and passed through the top of the seat back to aid removal, the seatbelt trims simply click out.
i cant remember if you need the higher boot trim carpet to cover the amp, or it just fits with the new bracket on top of the cd changer ,
the armrest and gubbins will have to come out to allow the loom to pass from the back seat over to the console under the armrest and up behind the stereo
the HK system does not use door mounted tweeters ( in the door pull handles ) but mounts them in the a-pillars in stead, you cant have both , its one or the other, the loom should already be there in the pillar, but may not depending on the year of your car, if not, a simple pair of wires from the head unit to the pillars is required,
though , there is nothing stopping you using the HK tweeters in the door if you want, but its not an original HK installation
i would say this is two days work for a garage to do correctly, and remember 80% of your interior is being removed, so take a photo of each door and seat before its worked on , and make sure every nut bolt and screw is refitted after the job i done
nothing worse than bad fitting interiors
hope this helps
and good luck
hope this helps
and good luck
blackflash
Thanks BB!
Sounds like the parcel shelf plus sub-woofer is the biggest culprit! Still, no point in upgrading the rest without that...
On tweeters, I may have mistyped so to be clear:
Front: A-pillar HKs are inserted and existing door-mounted tweeters are idealy removed (yes, I even have the non-mesh handle surrounds to do this) or at least (in case anyone else is mad enough to attempt this) disabled/ignored.
Back: the normal tweeters are removed and replace by HK ones.
Photos a good idea.
All the best,
Nigel
Photos a good idea.
All the best,
Nigel
Blackflash
Hi all,
regarding the Premium sound system and specifically the H/K amp: Does anyone know if the amp includes built-in equalisation for the appropriate vehicle and speaker units used? For the subwoofer there must naturally be a low-pass filter, but anything else?
This popped into my mind as at least Bose tends to do this...
Cheers,
- Ari -
Cheers,
- Ari -
1999 XJR - 7" LP, Quaife ATB etc.
blackflash
Hi all,
Cheers,
- Ari -
No idea what you're talking about I'm afraid, Ari - and I'm a hi-fi buff at home! I doubt whether you're going to find anyone on the forum who can answer that sort of specialist question but wish you luck and will keep watching the topic. All the best.
Cheers,
- Ari -
Blackflash
Yeah, I know - I was more or less thinking out loud, when posting. To me the problem is that I am unable to control any of the parameters inside the system. This is, of course, typical for a factory installed system.
I checked the subwoofer position on the rear parcel shelf and it's very tight indeed - furthermore I have a roller blind there, which really makes things difficult(I don't want to take it off). I'd be prepared to replace the factory sub with something else, but the lack of control in the amp(no selection for x-over points nor volume level adjustments) may make it impossible to fit it into the existing system.
I did track the H/K amp and harness in the U.S., but I am having now second thoughts.
The best bet seems to be an ALL factory system.
Have to think about this...
- Ari -
- Ari -
blackflash
- Ari -
In the original options list, you had to choose between rear blinds and the premium sound system due to the physical constraint of available space. It is therefore a "given" amongst the X308 owning fraternity that you can't have both - certainly not if you go down the "standard" premium system route. If you find an alternative set-up which is visually subtle and sonically mind-blowing then be sure to share!
All the best,
Nigel
- Ari -
All the best,
Nigel
Blackflash
subwoofers ect
Fascinating stuff with you guys who obviously know your woofers from your foo foo valves.........my system on my old XJ40 got out of sorts so i just bought a Daimler........
anything electric, i leave well alone, but all power to your elbows boys it must save you a fortune...............Joe
- Ari -
All the best,
Nigel
almost.......
you can have split rear screen blinds with the sub-woofer mounted in the rear shelf, essentially two smaller blinds either side of the woofer , i have one large blind, so sadly, no sub-woofer
just replace the standard woofers in the doors with high quality units, and some good tweeters in the doors ( if that is where they are in your car ) and that will improve the sound from the head unit, which is actually quite an expensive high quality unit,
if you really want to amplify and split the frequencies, then your into a host of after-market products and lots of wiring, and to be honest, i would rather spend the money on more petrol and listen to that fantastic engine purrring away
- Ari -
All the best,
Nigel
almost.......
atlegranby
blackflash
Harman-Kardon Premium Sound System installed at last!
I wanted to let you know that I have now had my premium sound system installed and it sounds fantastic. It took Dave Marks just over a couple of days to do, so BB was spot on.
This was the one key thing missing from my ideal spec when I bought my XJR.
The tweeter grills in the A pillars look good as well as sounding it, and the sub-woofer grill in the rear parcel shelf looks like it means business... which it does.
For the avoidance of doubt, the purpose is not to pretend to be a teenager by banging out loud music with the windows down! The clearer treble and much more solid bass makes listening to any type of music a much enhanced experience.
On the way back from the garage, where I had also had a 10k service and noisy front wheel bearings replaced, I listened to the sound system for the first half of the journey.
Then I switched it off to listen to the silence (thank you, wheel bearings) and the purring of the engine. The XJR in sport mode is a beauty to behold, in sound and performance terms - I still keep pinching myself to check I'm not dreaming about the kick in the pants I get. What a machine.
All the best,
Nigel
All the best,
Nigel
Blackflash
Nigel,
top marks for hanging in there and getting all the bits required to retro fit the upgraded sound system,
i have thought about doing this myself, but dont think i will now as i cant be arsed, lol
i did get a satnav head unit at one point, but couldnt fit it as they changed the wiring loom three months after my car was made for the 2000MY model, typical,
got ay pics of the install ?
