Front wheel bearings
Moderators:robv12, DavidEm
danr
Postby danr » Thu Jan 10, 2013 2:51 am
Hi guys,
got a noisy bearing n/s front, easy to change and do i need any special tools?
Thanks guys
robv12
Re: Front wheel bearings
Postby robv12 » Thu Jan 10, 2013 9:26 am
308 front wheel bearings are notoriously difficult to change
the upright has to come of , secured on the bench, them a special ABS rotor removal tool has to be used to remove the ABS pick up rotor, the bearing has to be pushed out with a press and pushed back in the same way
The ABS rotor is the problem, the torque setting is massive, some one will chime in with the correct figure, the rotor lugs can corrode, leaving the tool not seating correctly, hence making the undo even more difficult. The last one we did we had the rotor red hot , the biggest gorilla breaker bar plus a scaffolding tube and three of us on the bar, it finally came away with a huge "crack", the bench moved, all the crap fell out of the ceiling, an epic front wheel bearing change
Not all will be this bad, but none are easy, the rotor tool is avaibale to hire from our tools and spares, give Annie Jenkins a call
http://www.jec.org.uk/shop/99/suspensio ... -hire.html
good luck and keep us posted
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
danr
Postby danr » Thu Jan 10, 2013 3:08 pm
Hmmm think ill chicken out n get it done in garage :-)
Thanks guys
robv12
Postby robv12 » Thu Jan 10, 2013 5:53 pm
always best to ask first, even if the news is bad, imagine being half into this job and getting stuck, usually on a Sunday afternoon with the other car trapped behind a broken Jaguar, been there!!!
good luck , keep us posted on progress
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
